Problem with my 2001 Suzuki GSX-R600 - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
  • Print view
Advanced search
6 posts • Page 1 of 1
buc4933
  • Quote
#1 Post by buc4933 » Thu May 11, 2006 7:35 am
Here’s there problem, the bike is fine when your going along at 45 or faster, its when your going slow is when I have the problem. The other day I was riding it into the city and it started bucking or a hiccup as I’ve heard it called before, when I had a steady throttle on it. It felt as if you were just giving it gas real quick and then let off, and then keep doing it. Again it only did this when I was going slow, it even stalled on me a couple of times when I was coming to a stop. When I got home on the back roads I went slow again as if I were in the city and I didn’t have a problem with it. A little bit about the bike it's a 2001 Suzuki GSX-R600 with 5,600 miles on it. If anyone has any idea please let me know.
CORSCO
  • Quote
#2 Post by CORSCO » Thu May 11, 2006 7:41 am
Did the bike sit for any amount of time without running?
buc4933
  • Quote
#3 Post by buc4933 » Thu May 11, 2006 7:45 am
I just picked it up about 3 weeks ago, and the guy who had it before me had it in his garage all winter. So it sat all winter, but since I’ve had it I been riding it as much as I can
gitarjunky
  • Quote
#4 Post by gitarjunky » Thu May 11, 2006 7:58 am
I don't know much about maintenance but it sounds like you've got a problem with your fuel injection. And since it was sitting, if it wasn't properly stored, the gas that was left in it could gum up some parts...probably just needs a good tune up and you'll be good to go.
2005 Suzuki SV650
Get a yellow one....they're faster
buc4933
  • Quote
#5 Post by buc4933 » Thu May 11, 2006 8:09 am
Hopefully that’s it, Thanks.
MontyCarlo
  • Quote
#6 Post by MontyCarlo » Thu May 11, 2006 8:46 am
Sounds like clogged fuel injectors to me.
I don't normally recomend snake oil solutions, but there is this stuff called "Sea Foam" that you can get at _good_ auto parts stores. You might have to call around a bit, but this stuff is amazing at degumming fuel systems. The other stuff like Techron and the no-name stuff aren't nearly as effective. One bottle will treat 2-3 tanks, and I would try this before resorting to more expensive measures.
"At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul."
  • Print view
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
