I read that when adjusting the valves that even though the notch may align with the T or C to mark TDC it may be for the exhaust rather than compression stroke, can that occur?
The service manual does throw up two diagrams (one for each piston side) that I believe is supposed to be the correct camshaft positions before doing adjustments. I recreated the diagram for piston 1:
The associated caption reads: "#1 piston TDC at End of Compression Stroke. Inlet valve clearances of #1 piston and exhaust valve clearances of #1 piston."
My question is: Are the dots suppose to be indicating the cam lobe positions? In other words for this one, each of the lobes should be pointing to the sides? Is that a correct assumption here or am I totally misinterpreting the diagrams? The reason why I'm asking this is because the aftermarket haynes manual seems to indicate that the intake/exhaust cam lobes for each piston should simply point up. Thanks again everyone.
