When is it time for new shocks?
yoda731
#1 Unread post by yoda731 »
Hey, folks. Thanks as always.
My Clymer's manual for my '81 CX500 shows how easy it is to change the shocks (also states that the shocks for my bike can not be maintained, only changed when they are done). But it doesn't give any info on how to determine if new shocks are needed.
I think I still have the factory shocks, now in their 25th year. Is that age alone enough to make it worth replacing them?
I think because of my lack of experience on any other bikes that I can't decide if they are done for or not. I have tried the different tension settings on them, but haven't been able to tell if any setting is giving a better ride than any other (softer vs. harder). After rides of two hours or so, I do have some aching in my lower back. Would this be related to worn out shocks?
If I replace them, is this a generic enough part for an early '80s cruiser than I can buy any brand, or will I go wrong with some brands and right with others? I found this set on JCWhitney for $80. Any cautions against them?
Thanks,
JC[/url]
'81 Honda CX500 Custom
Get busy living or get busy dying. That's G-d-d-mned right.
CORSCO
#2 Unread post by CORSCO »
Always be cautious with JCWhitney :laughing:
Just remember, you get what you pay for.
When you hit a bump, does it take awhile for the suspension to settle? Is it acting like a pogo stick?
If you push down on the suspension, does it shoot back up immediately?
If yes to any of these, then replace your rear shocks. Go to a dealer and have them check out there catalogs. I am sure you could find something available from an aftermarket company.
TechTMW
#3 Unread post by TechTMW »
JC Wimpy SUCKS.
Another thing to look at is whether or not the stanchions (The shinly metal rods) are rusted or pitted. If they are good time for new ones.
The best auality cheap shock you can buy is p[robably a progressive suspension setup., Be aware, you have to buy the Shocks and springs separately (Usually.)
I tried once to just use the old springs w/ new shocks ... didn't work.
