Question about rotating engine... - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
  • Print view
Advanced search
6 posts • Page 1 of 1
TheImp
  • Quote
#1 Post by TheImp » Sun May 28, 2006 11:24 am
Why would it happen when I tried to rotate the engine to TDC on compression stroke I reached the "C" mark for that cylinder and as I got close it just moved right passed the mark? It's as if the crankshaft had no tension as I cranked it with the socket wrench and passed it about 20 degrees or so. The only way I could get it to stay was to crank the small distance counterclockwise, but I don't think I should do that too much.
I ask the damnest questions sometimes but googling something like this isn't easy. :laughing:
"There are a terrible lot of lies going around the world, and the worst of it is half of them are true."
- Sir Winston Churchill
06 Kawasaki Vulcan 500 Ltd.
jmillheiser
  • Quote
#2 Post by jmillheiser » Sun May 28, 2006 11:38 am
my CX500 does the same thing. it will rotate past TDC on the right cylinder easily, even with the spark plugs removed which should eliminate any compression
TheImp
  • Quote
#3 Post by TheImp » Sun May 28, 2006 11:45 am
Do you think having either the intake or exhaust valves not sealing properly (since its on the compression stroke) that perhaps that happens? I mean its virtually impossible to hold it at that position once I'm approaching it, it just zooms right past it as the socket wrench brings the mark into the window with barely any force.
jmillheiser
  • Quote
#4 Post by jmillheiser » Sun May 28, 2006 11:51 am
try pulling your spark plugs. the zooming past the TDC point is more likely the compression pushing the piston down on what would be the power stroke (that happens right after TDC)
TheImp
  • Quote
#5 Post by TheImp » Sun May 28, 2006 12:04 pm
ok, will try it out. Appreciate the help. :)
DRam
  • Quote
#6 Post by DRam » Sun May 28, 2006 5:10 pm
If this is happening with the spark plugs out (as it does on my bike) it is likely that one or more of the valves are part way open. The valve springs will tend to push the cam forward (or backward, depending on position) and that in turn moves the crank. If the spark plugs are in, it's very possible that compression is moving the piston and taking them out might solve the problem. Sneaking up on TDC helps, as does using a breaker bar, which doesn't ratchet, to turn the crank and hold it in place.
  • Print view
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
