1999 suzuki katana question
rainpain666
#1 Unread post by rainpain666 »
hey,
i dont know what type of break fuild i have to out in this bike. i forgot to close the valve when i was working on the back breaks so the fluid leaked out everywhere. and i think its DOT4 but im not to sure. can someone help. thanks
TechTMW
#2 Unread post by TechTMW »
Your master cyl reservoir cap should say which type to use - So should tour Owners Manual. DOT 3 and DOT 4 can mix, so it shouldn't be an issue. Only difference is DOT 4 has a higher boiling point. Sure hope you didn't spill that stuff on your paint :(
PS. DOT 5 does NOT MIX with DOT3 or DOT4
I REPEAT NEVER MIX DOT 5 W/ DOT3 or DOT4!!!!! :light:
rainpain666
#3 Unread post by rainpain666 »
hey thanks
naw i just got it on the tire. i burned it off tho.
