My bike is running on a 6V electronic ignition system that works well, and charges even if the whole thing is rather weak, and the battery drains very easily with the engine off, making me think maybe the battery is dieing. Anyway I whippped out the multimeter to check the voltage from the battery
With the engine NOT running, the battery registers a 1 Volt drop when the pilot and rear light are turned on, with full headlight and rear light it drops 2V, ie the multimeter reads 4V over the battery terminals...
Is this type of voltage drop normal with a battery, or is the battery bad, or is something wrong with the wiring somewhere?
Thanks
Tyrone
Electical questions
- Veteran
- Stratus311
How old is the battery? Have you tried putting it on a charger over night? Sometimes a battery can be charged but not to full capacity which could cause a voltage drop. Some drop is normal.
[img]http://www.careercoders.com/images/Small-pictures/bike-sig.png[/img]
"Fighting for peace is like screwing for virginity."
“When you step on the brakes your life is in your foot's hands”
-George Carlin
-George Carlin
- Veteran
When charging a bat that small you will need a charger that will put out a small charge. Use a trickle charger or a batt charger that will put out a 2 amp current for your charge.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
one seater
horn relocation
