I just changed the brake fluid and did an oil change, pretty fun for a first time. I was thinking about bringing it to a mechanic place to drop, and I was wondering what do you guys do with old oil and brake fluid? On a side note, the oil change took longer to do than the breaks, which surpised me. When I first tried to bleed the brakes, no fluid was coming out, and I was like
. Than I read the manual again and saw that I had to open the valve, which made everything so much easier
. Oil change was easier but the drain bolt and bolt that holds oil filter were really stuck on there, but nothing a little WD-40 couldn't take care of
