I am restoring a 1980 Kaw Kz750 Twin and have run into a dead end. All is done on the bike BUT, here comes the part where I need someone's input. I'm sure it's something very simple but my frustration has caused it to appear more complicated!! My problem is that I can't get a good spark to the plugs. The bike will idle with the choke on ONLY. The minute you open the throttle, it dies! I've changed the coils, tried 3 coils that I know work and to no avail. Carbs are rebuilt. Has new points and plugs. Wires are good. Has new battery, new starter solenoid, and wiring harness is just fine. Can anyone help?? What could be the cause? Sure appreciate what you can offer. Thanx
