92 katana shifter
roscowgo
92 katana shifter
#1 Unread post by roscowgo »
Hey yall, got my forks re-mounted and a gas leak fixed..... now for some reason my shifter isnt...shifting right. It Does shift, but the lever itself doesnt pop back down or up from the gear. Goes into gear fine, and the lever itself isnt any harder than usual to engage. just doesnt pop back.
any suggestions? thanks.
oh. 92, katana 600. bone stock.
Skier
#2 Unread post by Skier »
I'm unsure of the problem, but be sure to post up on the katriders.com forums.
roscowgo
#3 Unread post by roscowgo »
That i did skier, i suspect its the detent spring. er. or whatever the heck its called.
clutch assem wheeee i get to take the oilpan and exhaust off. ah well. been needin to paint the pipes with some high temp black anyway. /grumble. Duh again, part 27 i suspect
