gixxer 1000, stock gearing speed. unlimited - Total Motorcycle Community Forums
Skip to content
  • Quick links
  • FAQ
  • Login
  • Register
  • Print view
  • 1
  • 2
  • Next
Herzeleid
  • Quote
#1 Post by Herzeleid » Wed Jul 26, 2006 7:44 pm
hey guys/gals. i have a K2 gixxer 1000 and want to push 200mph.
i am starting the work on the bike to make it possible but even with yoshi exhaust, Power Commander, K&N filter, and top speed derestrictor.. im not sure if the gearing is up for it. how much will one tooth off the countershaft give me at that speed?
also, as far as nitrous kits.. is there a setup that any of you recommend?
thanks.
- Herzeleid
Ninja Geoff
Real Name: Geoff
  • Quote
#2 Post by Ninja Geoff » Wed Jul 26, 2006 7:51 pm
a front sprocket getting smaller lessens the top speed in each gear. go smaller in the rear for top speed.
Skier
  • Quote
#3 Post by Skier » Wed Jul 26, 2006 7:51 pm
^^^^^ if he's running out of power before hitting redline, he would get higher top speed by dropping a tooth. Otherwise it will have the opposite effect of what he's looking for.
I'm going to assume you're not running out of gear (engine redlining) before topping out, so a tooth off the front sprocket will net you about, uhh, I think 1.5 teeth increase in the rear. There should be calculators online, or in spreadsheet form, that can tell you top speeds with current gearing. From that you can change values and see what your ground speed will be at with modified gearing. Try checking out GSXR forums for one. I'm almost certain there's one out there. If not, and you're feeling industrious, you can make your own. Gear ratios and tire dimisions are all easily found, along with the other information you require.
My Radian's spreadsheet has the following values:
Engine speed (RPMs)
primary drive ratio
gearing for gears one through six
front and rear sprocket count
final drive ratio
tire diameter and circumference
Calculation:
RPM / Primary Ratio / Countershaft Ratio / Final Drive Ratio * Tire Circumference(in feet) * 60 / 5280 = MPH
  • Quote
#4 Post by Sev » Wed Jul 26, 2006 7:52 pm
To be honest, I don't think that a lot of our members would really know what to do to help you out. But it sounds like you're on the right track.
Dropping one tooth in the front will definately increase your top speed, but it'll hurt the acceleration.
Be careful out there though, I'd hate to see you on the news.
JC Viper
Real Name: JC
  • Quote
#5 Post by JC Viper » Wed Jul 26, 2006 9:02 pm
Increase the front sprocket tooth count and drop the rear sprocket tooth count for increase in top speed but a decrease in initial acceleration. Sometimes though the bike will not rev to the max limit when this is done and thus you may end up with only a 5mph gain overall.
Another place to look for an increase in speed is finding any kind of limiter and removing it. Increase air flow to the engine, increase exhaust flow to let the engine breathe easier.
Expensive options are to increase the compression ratio with higher compression cams and pistons and maybe also a flywheel change.
Be good, don't goof, squids give us a bad name as it is.
VermilionX
  • Quote
#6 Post by VermilionX » Thu Jul 27, 2006 3:22 am
you can't do it w/o a TRE.
TRE will limit it to 186mph in 6th gear, unless you can magically make it run 200+ in 5th gear.
and i really doubt you can push it to 200+ w/ just a sprocket change.
Herzeleid
thanks guys
  • Quote
#7 Post by Herzeleid » Thu Jul 27, 2006 7:59 am
i have a TRE installed on the bike already.. the bike is capable of going faster than 186, but im worried if i change the gearing too much that it will not be able to reach its redline. that info should help quite a bit though, thanks.
- Herzeleid :D :stickpoke: :ninja:
black mariah
  • Quote
#8 Post by black mariah » Thu Jul 27, 2006 8:16 am
The question on my mind is... *WHERE* are you trying to hit 200 at? Bonneville? Maxton? The setup of the track you're going to use plays a *BIG* part in what you need to do to the bike.
Skier
  • Quote
#9 Post by Skier » Thu Jul 27, 2006 12:50 pm
VermilionX wrote:you can't do it w/o a TRE.
There is nothing magic about boatloads of power and different gearing.
bcarlson
  • Quote
#10 Post by bcarlson » Thu Jul 27, 2006 1:35 pm
Speed in that range is dictated mostly by aerodynamics; nothing else (although red bikes have been proven fastest in clinical trials :wink: ). Add enough horsepower and I suppose 200 is possible BUT it would be much simpler and cheaper to improve either your frontal area (tuck in) or improve your drag coefficient (get a PhD in CFD).
Basically, to double your speed you need an 8x increase in power. Max speed based on available hp is based on the following formula:
Vmax=56.44(maxhp/(Cd*A))^(1/3)
maxhp = max horse power (hp)
Cd = coefficient of drag (unitless)
A = frontal area of bike + rider (square feet)
Put this in Excel, fiddle with the numbers and you'll see how a small change in Cd will have a large effect on top speed.
Enjoy
  • Print view
  • 1
  • 2
  • Next
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
