Well, I have problems, BIG Problems. I noticed the other day that the thing was wobbling and nowhere as secure as it once was. On further inspection, I noticed that there was a crack on my rear cowl top section where the rear grab rail is (the TC-rack).
On further inspection, and after taking my seat off, I noticed that the Metal brace (the TC-rack) that holds the screw casings that enable the rack to be secured to the bike, is cracked on one side and pulling off slowly from the frame at the back of the bike, hence the wobble. I have never had any more than 5-10 pounds of maximum weight in the K5 case itself, and mostly less than a couple of pounds in weight, So overloading the case and putting excess strain on the brace was never an issue. I dont know how this has happened, but I did notice last year that the k-wing rack would cause "creaking" in the surrounding parts of the bike when grasped on to at all.
I am going to have to take the rear cowling off and hopefully get the metal bracket, RE- welded to the frame and on the one side where it is actually cracked in two, welded together.
I can see no other reason for the damage other than the rack and top case not being able to be sufficiently supported by the bike frame,and fatiguing prematurely causing fracture.
In the event I am actually able to get the repair done, I am hesitant to put the k-wing and top rack/top case back in use, as I am concerned of the same thing happening again, knowing fully well that generally speaking, when welded again, the fix is generally stronger than before, even still, I hesitate to re-apply.
I sent this concern to twistedthrottle.com for consideration, as the "riderhaus" site I bought the equipment off no longer exists as a distributor/dealer, and all previous e-mail/links I had was automatically forwarded to them. They in-turn sent off my concerns and pics to krasuer in germany.
I got the following reponse from Krauser...
Hello,
the TC-rack of the Bandit 1200 from 2001 on isn´t very strong.
It can be loaded only with 5 kgs. / maximum speed 130 km/h.
If the driver loads too much and/or drives too fast, there is
the danger, that the rear frame will break.
On the mounting instruction, there is an indication to the
maximum load of 5 kgs.
Best regards
Rainer
I e-mailed Twisted throttle back with a second e-mail, and asked that it be forwarded to krauser, They have indicated that they will help as they are able. Erik at Twisted Throttle mentioned to me that "Twisted Throttle Ltd is only a dealer for Krauser; Riderhaus was a separate dealer for Krauser." and that " We will do our best to facilitate an information exchange between you and Krauser, but please understand that product technical performance is something we as a dealer do not have control over."
So, I e-mailed Krauser directly after a prompt reply from Eric at Twisted throttle with the necessary contact info.. with the following...
Dear sirs At Krauser.
Presumably, you have been aprised of my predicament via Twisted throttle Ltd out of the U.S.over the damage done to my motorcycle by your product which was purchased via Riderhaus approximately 20 months ago.
I would like for you to know that I too am also very aware of the load parameters and speed restriction with the unit. However, I have never had more than 10 pounds of weight at ANY one time ( 5 Kg equal to exactly 11.02300 lbs, and that very rarely. Also, I have never taken my motorcycle past 120 Kmh with the case on.
With these restrictions adhered to via personal responsibility to stick to the manufacturers guidelines and recomendations, I am perplexed that this would still happen. I also dont recall any fine print or other warning with regard to the TC-rack being weak anywhere displayed in your advertising, and definately not from the previous riderhaus website, or twisted throttle for that matter.
I certainly am not in the businesss of making an investment of over $500 CDN with the full knowledge that that investment will be made redundant and rather valueless within 2 years after the purchase and use of that product, As I am sure neither are you . ( Note: The motorcycle with the case attached has been used less than 6 months, and the rack without any case attached, less than 12 months as ther are 5-6 months of NON-RIDING weather here in Canada.)
I will ask you for a response "other than" information as to the weakness of the motorcycle manufacturers TC-rack. That and the assumption that the product was not used within manufacturers specs, as I have stated, which is not the case.
Damage has been done to my motorcycle via use of your product, Up until now, I have been a fan of your product and was planning on purchasing the side case units this year via your "twisted throttle" dealer in the U.S.
I need a more constructive response with regard to my concern other than the abrupt and presumptous implication that I havent used the product within the factory/manufacture tolerances, (the following examples would be better routes to take, i.e :"suggestions on how to avoid this from happening again, should I decide to take a chance and re-install you product after the damage is repaired" or/and "some sort of Compensatory gesture that will help with regard to the repair of the damage done to my motorcycle as a direct result of your product.)
I have held Krauser in fairly high regard and have reccommeded your product to fellow riders on several occasions during its time via showcase appeal on the back of my bike. I trust this free advertising is not in vain.
If a mutually satisfactory outcome is achieved for both of us, then this can and will be the end of my problem, However, If, Again, I appear to get the "brush off' from your organization, I will have no choice but to pursue further action. Not the least of which will be posting and documenting my entire experience with your product on the web and within private Motorcycle forums for the benefit of all potential consumers.
Im not sure how customer service works in europe, as it has been many years since I left there, however, Customer service and product support is paramount here in the west I can assure you, This Im sure can be vouched by your U.S distributor/dealer also.
I havent heard back any response yet, then again, I only recently sent the e-mail. So I'll keep this post.. POSTED?
later
Snubnose
