CNF2002 wrote:Check your owners manual, not necessarily the tire (especially if it is a nonstock tire).
I do not know alot in this area but, does anyone see a benefit of changing tire pressure for twisty roads?
running a lower psi will make your tires warm up faster and have better grip.CNF2002 wrote:Check your owners manual, not necessarily the tire (especially if it is a nonstock tire).
Hmm...makes sense from a grip point of view. I always dropped the pressure on my jeep tires when doing any serious rockcrawling. But, at the same time, running with lower psi in the tires would be a big no-no at high speed.VermilionX wrote:running a lower psi will make your tires warm up faster and have better grip.CNF2002 wrote:Check your owners manual, not necessarily the tire (especially if it is a nonstock tire).
tires get harder after warm up... so if your pressure high already even at cold, it's gonna be even higher when it warms up. too hard tires doesn't grip the road as good as softer tire.
the only bad effect is see running a lower psi is faster wear on tires.
but if you wanna try something a little more aggressive in the canyons, it's better to run a lower psi.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
Follow us on X / Twitter - Facebook - YouTube - Pinterest - Instagram - News RSS Feed |
