PS: I've seen some bikes at night pop, they do sometimes have a little blue light at the tip. Nothing major.
2002 Buell Blast 500 /¦\
Anyone want to comment on whether this 'condition' is harmful to the bike in any way?
Running lean on the overrun (throttle off) shouldn't be an issue at all unless it's excessive and blows out your muffler packing. If it's just a little cough or pop occasionally, then it's a non issue. If you start running lean under power though, then that is a problem. It can raise the exhaust gas temperature to the point where it will melt valves and put holes in pistons.
Verm - I'm not sure if you were kidding, but in case you weren't, a "lean" condition is when there is not enough fuel in the cylinder to use up all the oxygen during combustion. If you have more fuel and not enough oxygen, it's running rich. If you have the right ratio (14.7 to 1 by weight), it's a stoichiometric mixture. Typically for best power you want to run a little rich, and for best fuel economy a little lean, though there are other side effects of both.
Posthumane wrote:Running lean on the overrun (throttle off) shouldn't be an issue at all unless it's excessive and blows out your muffler packing. If it's just a little cough or pop occasionally, then it's a non issue. If you start running lean under power though, then that is a problem. It can raise the exhaust gas temperature to the point where it will melt valves and put holes in pistons.
thanks for the explanation.
and yeah, it doesn't backfire constantly on mine so i guess that's normal.
