So my bike is only running on two cylinders. WTF?
bike was runnign good up until my holidays. Let it sit for a week and now only "running" on 1 & 2.
Haven't got the plugs out yet but, they are only a month old. As are the carbs "cleaned and synced". First thought would be fouled plugs. But there's got to be a reason why two plugs are fouling after a month. Cause might be carbs are dirty and set up wrong, but I just had them done. Do I need to to lose it on the guys at the shop and have them done again?
What gives? I'm frustrated.
cylinders 3 & 4 not firing
- rapidblue
- Legendary 500
80 honda CB750F Super Sport
- Legendary
how is your carb setup? 2 carbs feeding 2 cylinders each or 4 carbs? If it is the first setup @ carb) try tapping the float bowl with a screwdriver or taking out the drain to see if you are getting fuel. if you are then check the plugs, after that check the carb and clean it out, I had the same problem on my bike
83 GS550, 70 Yamaha CT1 175
- rapidblue
- Legendary 500
It's four carbs, I finally took the plugs out and they were all fouled, 3 and 4 were worse than 1 and 2. They are black. Not sure if its fouling from fuel or oil. Didn't look hard enough.
Put in new plugs and it runs fine. Obviously there is still a problem. Something is fouling the plugs fast.
- bok
not to be a conspiracy nut, but are you sure they put new plugs in? pull the plugs again after a few miles and see how they are, if they fouled up that fast on you, i would assume they would do so again.
- rapidblue
- Legendary 500
haha yeah, they gave me the old plugs. But were they MY old plugs (puts on tinfoil hat....)bok wrote:not to be a conspiracy nut, but are you sure they put new plugs in? pull the plugs again after a few miles and see how they are, if they fouled up that fast on you, i would assume they would do so again.
