Throttle problems
Posted: Tue Aug 08, 2006 11:08 am
by sp4d3r
[/b] Hello, I'm wondering if anyone can help me. I came back from a ride on my 1991 Yamaha RT 180 and my throttle seemed stiff. Next day I go to try it and it barely works, doesn't twist all the way down and even sticks at high revs when the bike is on. Can anyone help me or give me info to try and fix this problem? thanks.
Re: Throttle problems
Posted: Tue Aug 08, 2006 11:18 am
by totalmotorcycle
sp4d3r wrote:[/b] Hello, I'm wondering if anyone can help me. I came back from a ride on my 1991 Yamaha RT 180 and my throttle seemed stiff. Next day I go to try it and it barely works, doesn't twist all the way down and even sticks at high revs when the bike is on. Can anyone help me or give me info to try and fix this problem? thanks.
Might be a simple fix if it's your throttle cable sticking. You can try the poor man's way of fixing it by buying a cable luber (about $5) and a can of WD-40, Liquid Wrench or simular and spraying it really well. Or replace the cable.
Mike.
Posted: Tue Aug 08, 2006 1:27 pm
by sp4d3r
It's not that my throttle is litterly sticking, my throttle would be "off" and the bike would still be reving high. I adjusted the idle speed before this happend so maybe that got turned?
Posted: Tue Aug 08, 2006 2:11 pm
by BuzZz
Something is probably sticking. Either the inner cable or the slide in the carb itself.
But if you adjusted the idle, and either set it too high or adjusted the airscrew instead of the idle screw, it could be that. Almost sounds like the air screw was set too lean, this can could the motor to race when it is unloaded.
