Throttle problems
Throttle problems
[/b] Hello, I'm wondering if anyone can help me. I came back from a ride on my 1991 Yamaha RT 180 and my throttle seemed stiff. Next day I go to try it and it barely works, doesn't twist all the way down and even sticks at high revs when the bike is on. Can anyone help me or give me info to try and fix this problem? thanks.
yo
Re: Throttle problems
Might be a simple fix if it's your throttle cable sticking. You can try the poor man's way of fixing it by buying a cable luber (about $5) and a can of WD-40, Liquid Wrench or simular and spraying it really well. Or replace the cable.sp4d3r wrote:[/b] Hello, I'm wondering if anyone can help me. I came back from a ride on my 1991 Yamaha RT 180 and my throttle seemed stiff. Next day I go to try it and it barely works, doesn't twist all the way down and even sticks at high revs when the bike is on. Can anyone help me or give me info to try and fix this problem? thanks.
Mike.
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
Something is probably sticking. Either the inner cable or the slide in the carb itself.
But if you adjusted the idle, and either set it too high or adjusted the airscrew instead of the idle screw, it could be that. Almost sounds like the air screw was set too lean, this can could the motor to race when it is unloaded.
No Witnesses....
