Im running Honda hp4 10/40 and its clean and at the right level.
A guy that i work with says he had the same problem with his nighhawk. he took it to a couple of dealers and they claimed it was a bent shift fork and they would be more than happy to sell him a new motorcycle cause it would be more cost than worth to replace the bent shift fork.
He ended up trading that nighthawk and the new owner took it somewhere and the guy adjusted something and its running fine to this day.
Ive been babying this thing pretty bad. i havent gone over 7000 rpms. so im questioning it being a bent shift fork. and also if it was a bent shift fork, wouldnt it also do this when it was warming up? and also in the lower gears. it seems to mainly happen in 4th gear. coming down from a good ride in 5th.
My real question is... what could be adjusted on this beastie to attempt to fix my problem. im gonna pick up a climbers manual tomorrow. and paw through it. id like to attempt to fix it myself before i find myself in a show room with my credit card in my hand, nodding to "bent shift fork, you need a valkyrie..."
