If you cross state lines do you need a helmet?
flw
#1 Unread post by flw »
I found a link to a list of all states and if they require a helmet or not and by age. See http://www.ghsa.org/html/stateinfo/laws ... _laws.html
Safe traveling as we get closer to a traveling holiday.
Goldwing 1500se '98
VN500 LTD '07 Sold
Andrew
#2 Unread post by Andrew »
Good info. Thanks.
2004 BMW K1200RS
[img]http://www.bmwlt.com/forums/images/smilies/BMWsmile.gif[/img]
storysunfolding
Years Riding: 22
#3 Unread post by storysunfolding »
...I thought maryland didn't have a helmet law. Is this up to date?
My Blog
Grasp life by the handlebars
Scoutmedic
Real Name: Barry
#4 Unread post by Scoutmedic »
Great Link!
storysunfolding
Years Riding: 22
#5 Unread post by storysunfolding »
storysunfolding wrote:...I thought maryland didn't have a helmet law. Is this up to date?
Checked out the Maryland MVA website. Apparently you do need a helmet in MD.. I guess I just see alot of people up there that don't wear one.
My Blog
Lion_Lady
Real Name: Pam
Years Riding: 24
#6 Unread post by Lion_Lady »
YES, you are required to wear a helmet in MD. Must be DOT approved, min.
P
#7 Unread post by Sev »
As I understand it, you need to wear your helmet if the state has helmet laws stating that you must. Doesn't matter where you are from, why you are there, or how long you're going to be there. Gotta have a lid.
However, I suspect that some places have more lax helmet laws eg. Alberta requires a DOT skullcap at the least with the 1.5 or 2 inches of foam padding. Where-as BC I've seen guys with what looks like a leather cap with a chin strap on it.
It all depends upon the laws of the state.
And personally I'll always wear my fullface... only time I don't is when I pull my bike into the garage after opening the door.
In some states you only need a helmet if you are under 20 or under 17 or if you're a learner.
I think Colorado had no helmet law at all.
It's best to check each individual state before you go there. On the other, if you always wear your helmet, you won't have any problems. :)
jmillheiser
#9 Unread post by jmillheiser »
there is a reason why the sturgis crowd does NOT go through nebraska on their way to strugis. Nebarska is a helmet law state.
Helmet laws dont really concern me much. I always wear a fullface even if the law doesn't require it (like here in wyoming).
Wyoming only requires helmets for those under 18, colorado has no helmet law of any kind (I have seen children riding pillion in CO with no helmets), South Dakota has no helmet law, Nebraska requires a DOT approved helmet.
CTLawyer
The Helmet State Map I Used On My Recent Cross Country Trip
#10 Unread post by CTLawyer »
Try this map for a quick reference. I am confident it is correct as I checked most of the states and they have them right.
http://www.fastfreds.com/helmetlawmap.htm
2005 Suzuki M50 Addict
