AIS help
thumpjr
AIS help
#1 Unread post by thumpjr »
I keep hearing people talking about removing the Air induction system.. and I've looked every and all i can find is how to remove it. What I actually want to know is...what is it and what good does it do to remove it. If anyone could explain or point me in the right direction I would really appreciate it.
Cruisin...theres no better feeling in the world.....unless you could combine sex with riding....but lets not get greedy
#2 Unread post by BuzZz »
Systems vary a bit from make to make, and since your keeping your model a secret :? I'll just guess. :mrgreen:
Generally air induction is used to help lower emission readings. Not emissions. All they do is pump clean air into the exhaust, diluting it and therefore giving a lower reading of pollutants in the exhaust. This keeps the pencil pushers at the EPA happy without actually doing anything to reduce the amount of pollutants produced by the engine.
Some claims are made that the extra air helps complete combustion of the exhaust in the exhaust pipe, and it may do so, but really this happens very little, if at all. Course I'm sure there are some who believe it does just that to a greater amount, but they are not the engineers and designers I've talked to.... so take from that what you will.... 8)
thumpjr
#3 Unread post by thumpjr »
thanks for that info...i have 06 1100 v-star by the way..my bad :lol: So if I removed that system..would it mess with my stock air intake? I really dont know much about this really...I 've heard people mention they have removed it do get rid of the popping in their exhaust.
betabilly
#4 Unread post by betabilly »
Just plug the openings good. Removing the AIS is not a performance mod, removing it reduces throttle roll off popping when you install induction mods and big main jets.
Some concerns on AIS removal on newer V-Stars with catalytic converters.
thumpjr
#5 Unread post by thumpjr »
what are the concerns? I really don't wanna mess anything up by removing the AIS.
