Does ANYONE make inexpensive ignition coils???
Andy G
#1 Unread post by Andy G »
I need a new ignition coil for a 1978 Honda CB400TII Hawk. Mine still works, but when it gets hot it cuts out.
Cheapest I have found is around 100-125 bucks. I only paid 300 for the motorcycle...! Doesn't anyone make something less expensive???
Thanks!
Andy
flynrider
#2 Unread post by flynrider »
Check around the Internet for an Accel coil that will fit. Accels are usually priced lower than the Dyna coils and will do fine on your 400. I've seen Accels from around $75-$95.
Bikin' John
'93 Honda CB750 Nighthawk
roscowgo
#3 Unread post by roscowgo »
spent 180$ on the two that go on my bike when i had to replace em. :)
oldschoolorange
#4 Unread post by oldschoolorange »
how many leads does the coil have 1 or 2? I have bought single lead coils for about 40.00 cnd, If you are really tight for cahs buy a used one
83 GS550, 70 Yamaha CT1 175
koconno2
#5 Unread post by koconno2 »
I found a new stator by Electrix for my 81 CX650 through them. First go to Electrex.com and check to see if they make what you need. Then buy at one of their dealers.
KPO - First Time Rider
1983 Honda CX650 Custom
Belleville, MI.
giantrobot
#6 Unread post by giantrobot »
The JCWhitney coils are decent replacements.
http://www.jcwhitney.com
Call your local parts shop. They should have inexpensive replacements.
Scott
http://gallery.photomob.org
