dropped my bike and know it wont turn over?
adam.88
#1 Unread post by adam.88 »
it was parked and fell over and part of the clutch handle broke off, know it wont start. any ideas on what could have happened?
INFO:
04 suzuki GS500f
lights still turn on
fireguzzi
Real Name: Trevor
#2 Unread post by fireguzzi »
Does the starter still spin the engine over?
Or is there nothing when you hit the start button?
wildweasel
#3 Unread post by wildweasel »
Kill switch? (this is if it turns over but won't start)
adam.88
#4 Unread post by adam.88 »
it doesnt even turn over anymore.
fireguzzi
Real Name: Trevor
#5 Unread post by fireguzzi »
I would check the obvious stuff first, like the kill switch.
Maybe the clutch damaged the safety switch that is operated by the clutch.
But I would think that you could still start it in nuetral if that were the case.
hmmmm........
There is also a safety kill switch on the kickstand that may have been damaged.
It should not be any kind of major problem from just a little fall.
Good luck
