Suzuki C50 or Vulcan 900?
Suzuki C50
8
50%
Vulcan 900
8
50%
Total votes: 16
CycleNewb
#1 Unread post by CycleNewb »
OK guys, I'm considering both. Which would you choose and why - The Suzuki C50 or Vulcan 900?
ZooTech
Years Riding: 18
#2 Unread post by ZooTech »
For me, the Vulcan 900 (in LT trim). Having ridden both, I give the Vulcan a slight edge simply because it's more powerful. To me, the ergos and overall appearance are too close to declare a victor. The nice thing about the C50, though, is the cost of accessories. A 3-piece studded gel seat for the C50 sells for only $215.00, and you can debaffle the pipes very easily for a great sound at very little cost ($40.00 for two hole saws).
jstark47
#3 Unread post by jstark47 »
Vulcan 900:
1) shaft drive (C50) is my least favorite
2) slight edge in engine power
sharpmagna
#4 Unread post by sharpmagna »
Vulcan 900
Bigger engine (100cc difference)
Rear Disc Brake (C50 has rear drum)
Belt Drive (Shaft drive on C50) **This is a preference though you may prefer the shaft drive)
Lower seat height (good for shorties)
1987 Honda <B>SUPER</B> Magna
basshole
#5 Unread post by basshole »
C-50 is bulletproof and the best selling middleweight cruiser on the market. Nuff said.
Beer. Helping ugly people get laid since 1853
2006 Suzuki C50 Silver/Gray
DivideOverflow
#6 Unread post by DivideOverflow »
Vulcan. Bigger, stronger, and belt drive.
2008 BMW K1200S
2003 Z1000 - For Sale
2004 Hyosung GV250 - sold
William
Years Riding: 11
My Motorcycle: Newest: '15 ZX-14R Ninja, plus 2 others.
#7 Unread post by William »
I'd go with the Vulcan 900. It's a newer, fresher design, and like was said before, has a rear disc brake, and the belt drive will transmit more power to the wheel and not cause handling problems.
The Suzuki is a good bike, and a proven design, but the only real advantage is the low maintenance and strength of the shaft drive.
1982 Suzuki GS1100GL, 2013 Victory Cross Country Tour, 2015 Kawasaki ZX-14R Ninja.
2006 Yamaha Wolverine 450 sport/4wd ATV, 2009 Yamaha Grizzly 550 EPS SE utility ATV
2006 Toyota Tacoma TRD 4wd 4 door, 2008 Toyota Highlander AWD
Born, raised, and spent most of my life in Florida until I moved to Farmington, New Mexico April 2011. Yes, I'm in the wonderful Four Corners area.
CycleNewb
#8 Unread post by CycleNewb »
I just put a deposit on the Vulcan.
Doin' the happy dance! :kicking:
MotoF150
#9 Unread post by MotoF150 »
Vulcan! The C50 and the Vulcan is almost the same engine built by the same factory in China, but Kawasaki uses the same fuel injection system they use on their crotch rockets, but Suzuki FI system is a cheap spit type fuel injection causing the C50 to run rich and blow black smoke from the exhaust. I know cause I own a M50 and I was told there was nothing to do about the heavy black smoke from my exhaust cause the design of the FI causes the problem.
William
Years Riding: 11
#10 Unread post by William »
MotoF150 wrote:Vulcan! The C50 and the Vulcan is almost the same engine built by the same factory in China, but Kawasaki uses the same fuel injection system they use on their crotch rockets, but Suzuki FI system is a cheap spit type fuel injection causing the C50 to run rich and blow black smoke from the exhaust. I know cause I own a M50 and I was told there was nothing to do about the heavy black smoke from my exhaust cause the design of the FI causes the problem.
I had a 2002 Suzuki Intruder 800 (same engine as the M50/C50, but carburated), and it said "made in Japan" on the engine block.
I've looked at the Vulcan 900, and the engine looks quite different. I didn't pay attention to where the engine was made, but I can't imagine the proud Japanese letting the Chinese make engines for them.
