tachometer problem
bblacksheep98
tachometer problem
#1 Unread post by bblacksheep98 »
hi i have a old honda cb360t and the needle on the tachometer is sticking is there anyway to fix this it wont show anything past 2500 rpm.
CORSCO
#2 Unread post by CORSCO »
Lube it or replace it, the cable I mean. Or if the tach is trashed you will need to find one on ebay or salvage yard. I'm sure you could find one, the CB350 was one of the most common bikes back in its time.
