Using choke causes engine to die
Posted: Thu Dec 07, 2006 6:58 pm
by num23bulls
Have an 85 Honda Interceptor VF500. It's my first bike, and I've tipped it over a couple of times (parking on a hill where I work :-( ). Anyway, I'm having two, presumably related problems:
1) If the choke is pulled out, the engine will die. That means I can't use it to warm up the engine.
2) To get the engine to start, I need to open up the throttle a little and give it some gas. This was true even when the choke did work. So basically, I have to give it gas as I'm starting it and to warm it up, since trying to use the choke just kills the engine.
Occasionally it will stall out when I'm stopped, but when I'm moving it works fine, especially at higher RPMs.
As a side note, I have charged the battery. I start with the bike in neutral, clutch pulled in, gas on, and when it worked, with the choke pulled open. Though the weather has gotten a little colder, it's not exactly cold here in Southern California.
I've only put about 200 miles on it, for a total of about 13,800. Fluid levels look fine. Last time I tipped it, it leaked a little bit of coolant from one of the vent tubes, but only a few drops.
I've seen lots of posts where not using the choke kills the engine. But this seems to be the opposite problem. Any ideas?
Posted: Thu Dec 07, 2006 8:39 pm
by Johnj
First thing I'd do is remove and clean the carburators. There should be a tutorial somewhere on the net for your bike. Buy a CLYMER.or use Google.
Working now
Posted: Fri Dec 08, 2006 6:18 am
by num23bulls
Not sure why, but it started working normally again this morning. Maybe it just needed to sit and let the fluids settle. I'll post again if it starts acting up again.
Posted: Fri Dec 08, 2006 10:10 am
by logitech104
you might check your air filter really quick if you haven't for a long time. If it is dirty, air will have a hard time passing through, making the bike run rich. So when you pull the choke, it makes the bike even more rich and kills it. (Could flood the engine)
rich= more gas (per correct ratio) than air
lean=more air, less gas
