Ignition Troubles
Posted: Tue Jan 23, 2007 12:20 pm
So i've got about 600 miles on my bike now, i'm just about to take it in for it's first service (Still a newb, and i want it checked by a pro for it's first tune-up) But i want to have all the info i can when i take it in, hence my inquiry.
Since I've had the bike It's had trouble starting up about 4 times. I go to start the bike, make sure it's in Neutral, Hold the Clutch, Press the ignition... The engine starts to turn over, but never catches. The first a couple of times it just took a few tries then worked fine. But today at lunch it wouldn't start. I tried about 4 times with no luck before i gave it a little gas to help it turn over. This method worked,..but left me feeling like something is wrong. My rommate has a CBR 600RR and i've never heard his bike struggle to start.
A few more details.
- 07 Suzuki GSX-R 600
- I've only noticed the problem during the day, after it has sat outside in the sun for at least 10 minutes
- I do not use the emergency shut off when i park for the night, Only when i know i wont be riding for a few days.
- I do start my bike while it is on it's kickstand (in neutral obviously) to warm it up while i put my gear on.
Is it my technique? or could it be a bigger problem?
Again i'm taking it in to be serviced this weekend, but would like to know if i "shouldn't" be riding til then... for some reason.
Thanks all.
A few more details.
Thanks all.
