Well I'll be a monkeys uncle
http://www.cfmoto-usa.com/automaticmotorcycles.html
Any of yall seen anything from them before? a 250cc motorcycle styled cruiser. With built in am/fm/mp3 for 3500?
Thats danged tempting. Even for a chinese bike.
That has to be one of the friendliest looking noobie bikes i think i can imagine.
- storysunfolding
- Years Riding: 22
- Sev
Two levers up front, one is probably the rear brake if it's a CVT.jonnythan wrote:If I didn't know any better, I'd say it looks like they don't have a rear brake.
- JC Viper
- Real Name: JC
- Years Riding: 7
- My Motorcycle: 1984 Kawasaki GPz900R
It has a top speed of 75MPH even though there's a redline at 60 on the speedo. It's also marketed at a fuel efficient 70MPG. It's pretty comfy when i sat on both the V3 & V5. I think i recall it sporting a rear disc brake as well.
- dr_bar
- Real Name: Doug
- Years Riding: 44
Kind of selfexplanatory...
CFMOTO-USA V3 and V5 Specifications
(All specs are the same unless noted otherwise)
Engine: CFMOTO 172MM-A
Type: 4-Stroke, Single Cylinder, Liquid Cooled, Overhead Cam
Bore x Stroke: 72mm x 60mm
Compression Ratio: 10:1
Carburetion: ISO – Vacuum Diaphragm
Displacement: 244 cc
Max. Torque: 17.6 / 5500
Horse Power: 18 HP
Max Speed: 75 MPH
Ignition: CDI (Electric Start)
Transmission: Automatic CVT
Chassis
Suspension/Front: Telescopic (Oil-Damped)
Suspension/Rear: Twin Shock
Brakes/Front: Disc Hand Control
Brakes/Rear: Disc Hand Control
Tires/Front: 100/90-18 (36psi)
Tires/Rear: 150/80-15 (40psi)
Dimensions
Length: V3> 86.6" - V5> 88”
Width: V3> 33.5" - V5> 35"
Height: V3> 43.7" - V5> 44.1"
Seat Height: 27"
Ground Clearance: 5.5"
Wheelbase: V3> 58.3 - V5> 58.7"
Dry Weight: V3> 392lbs. - V5> 365 lbs.
Fuel: 90 Octane or Above
Fuel Capacity: V3> 3.2 gal. - V5> 4.5 gal.
Fuel Consumption: 75 MPG
Warranty: 2 Year Limited Warranty
Horse Power: 18 HP
Max Speed: 75 MPH
Chassis
Dimensions
Seat Height: 27"
- jstark47
- Site Supporter - Silver
I wouldn't trust the quality of bikes built in mainland China at the moment (this will change over the next 10-15 years.) But the concept of these bikes is something we'll see more and more of - blending the categories of motorcycle and motor scooter. Also see the new Aprila Mana 850.
