Suzuki 1400 Intruder Stalling issue
- floatsmyboat
- Veteran
My son just bought his first motorcyle, a 1996 Suzuki Intruder 1400. While riding it home I noticed it would sometimes stall when I pulled the clutch in (disengage), and sometimes when engaging the clutch. It even did it while sitting still once, but usually while pulling up to a stop. I believe the idle speed is set correct, if anything a little fast. It acts just like the ignition switch has been shut off. It will start right back up again, but stalling is annoying and dangerous in an intersection. My first thought was low oil, but oil level is fine.
Any ideas?
Thanks,
Greg O.
Any ideas?
Thanks,
Greg O.
- floatsmyboat
- Veteran
- Sev
If you're in gear and you try to start the engine without having your clutch in nothing will happen. Basically it stops you from launching the bike out from underneath you if you start it in gear.
- floatsmyboat
- Veteran
Thanks for the quick reply,
After I thought about it I remembered why there is a switch in the clutch lever, but doesn't that just control the starting circuit from energizing the starter without pulling the clutch? How would that affect the ignition? I guess I need to get a wiring drawing.
Thanks,
Greg O.
Thanks,
Greg O.
- storysunfolding
- Years Riding: 22
- floatsmyboat
- Veteran
I agree, it doesn't sound like the switch in the clutch but it never hurts to check that.
The only thing that bothers me is that it only stalls when the clutch is pulled or released. But the switch in the clutch lever should only open and close the starting circuit, but maybe it is shorting out causing the ignition to loose power.
Greg O.
- floatsmyboat
- Veteran
OK,
I have just learned more by fooling around. I turned the idle down lower to a slower speed. With the headlamp on high beam, I put the turn signal on and the engine stalls. So the question is, is the alternater not putting out at low speed? Is it the battery? This is where I will start looking.
Thanks,
Greg O.
Thanks,
Greg O.
- floatsmyboat
- Veteran
I really appreciate everyones imput here. I am learning a little more as I go. I put the voltage tester on the battery and was reading 12.5 volts while running fast idle, 2000 to 3000 rpms. I realize this is low. From my automotive experiance it should be 13.5 to 14 volts. I assume it should be about the same on a motorcycle. I put the charger on the battery till the charger quit charging it. I would like to cell test the battery, but it is hard to get to. After charging the battery I was showing 12.9 to 13.25 volts. Still low.
Do I start with a new battery, or go to the rectifier and stater? How does a person test these?
Thanks,
Greg O
Thanks,
Greg O
- flynrider
- Years Riding: 30
You need to get the battery out of the equation. After a fully charging it, check the voltage at the terminals with the engine off. It should be around 12.2 volts or better. If it's not, then your battery may be the culprit.
If the battery is bad, it could be dragging down your charging system.
Bikin' John
'93 Honda CB750 Nighthawk
