I've got an old gas tank, and the cap for it was destroyed by the previous owner (whole drilled through, wire stuck through to keep it closed). So I need to somehow replace or maybe fix the cap.
Most imporantatly, I want a working and safe cap. Secondly, I want ot to look good.
So anyone have ideas of how to deal with this? Here's a look at it:
http://www.ae.uiuc.edu/~onu/gallery/sachs/DSCN3332
I've got a couple of ideas. One of which is cutting it out and welding something new on, but that's pretty tricky. Otherwise, maybe shaving the rim down to the correct shape so that I can make sort of a "grenade pin" style cap, where a pin goes though the rim, and a new stopper sort of plug to keep it closed.
Fuel Tank Cap replacement
- Gadjet
- Real Name: Owen Clark
- Years Riding: 19
- My Motorcycle: 2020 KTM 200 Duke
- Contact:
Dennis Kirk has some aftermarket gas caps that you could probably pick up and have fitted to your bike. While the caps are made to fit specific bikes, I'm sure a competent welder could do the alteration to your tank to have the new cap fitted.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
