Yamaha V-Star starting problem
- Meanie
- Legendary
A friend of mine has a Yamaha V-Star Custom. When she starts it, it cranks once or twice as if it doesn't have enough juice. If she opens the choke, it'll start right away. I checked the battery and the generator which are both fine. The battery is holding at 13 volts, which is above the manual's requirement of 12.8 volts and the generator is putting out at 13.9 volts (the manual indicates 14 volts as good). The next step is to check the stator coil resistance then if all is good, it suggests replacing the rectifier. But I'd hate for her to have to purchase a new rectifier only to discover it's still doing it, though, we may not have a choice. Anyone ever experience this and/or have any suggestions what to check for?
Thank you
Thank you
Friends help you move. Real friends help you move bodies.
It sounds like the charging system is good. If the V-Star in question is an 1100, they have a problem of twisting the starter motors. Look at the long bolts that hold the starter assy. together and make sure they are straight, not twisted. Also the starter will make an "clunking" noise when activated, like the starter clutch going out.
- Meanie
- Legendary
You mean the internal bolt going through the center holder the gears and assembly, and not the actual mounting bolts, correct?CORSCO wrote:It sounds like the charging system is good. If the V-Star in question is an 1100, they have a problem of twisting the starter motors. Look at the long bolts that hold the starter assy. together and make sure they are straight, not twisted. Also the starter will make an "clunking" noise when activated, like the starter clutch going out.
I mean the two long outside bolts that hold the actual starter motor assy. together. One should be visible at the very top of the starter running lengthwise across.Meanie wrote:You mean the internal bolt going through the center holder the gears and assembly, and not the actual mounting bolts, correct?CORSCO wrote:It sounds like the charging system is good. If the V-Star in question is an 1100, they have a problem of twisting the starter motors. Look at the long bolts that hold the starter assy. together and make sure they are straight, not twisted. Also the starter will make an "clunking" noise when activated, like the starter clutch going out.
- Meanie
- Legendary
Upon viewing the bolt and starter, I noticed the top bolt appeared angled to the left, meaning, it appears the starter was trying to rotate counter clockwise. Upon inspection of the starter gears, it all appeared fine with no visible notice of damage gears/teeth. Is this an example of "twisting"? If so, is the only remedy to replace the starter or just the bolts or something different? What is the remedy to avoid this from happening again?CORSCO wrote: I mean the two long outside bolts that hold the actual starter motor assy. together. One should be visible at the very top of the starter running lengthwise across.
Thanks for the help, BTW.
- Social Distortion
- Legendary 300
- My Motorcycle: 2004 triumph thruxton
Yep, it is twisted. I always replace the starter because I am a dealership tech.Meanie wrote:Upon viewing the bolt and starter, I noticed the top bolt appeared angled to the left, meaning, it appears the starter was trying to rotate counter clockwise. Upon inspection of the starter gears, it all appeared fine with no visible notice of damage gears/teeth. Is this an example of "twisting"? If so, is the only remedy to replace the starter or just the bolts or something different? What is the remedy to avoid this from happening again?CORSCO wrote: I mean the two long outside bolts that hold the actual starter motor assy. together. One should be visible at the very top of the starter running lengthwise across.
