I just got done cleaning the carbs on the bike I just got 3 weeks ago or so. I disconnected the fuel and vacuum lines from the tank to remove it. When I pulled the carbs out, I noticed 2 more vacuum lines that I never disconnected, hanging there open. WTF are these? They weren't connected to anything before, and I can't find anything to connect them to.
That can't be good, right? Open vacuum lines letting not only air in, but unfiltered air. Anyone have one of these bikes and know what these lines go to, or what? The service manual shows the lines on the carb diagram, but doesn't say where they are supposed to go.
1980 Suzuki GS250 Vacuum lines
- Veteran
- Veteran
- flynrider
- Years Riding: 30
These could be the carb overflow lines. Did they originally route to the bottom of the bike? That would be a good clue. Many carb installations have overflow lines that will dump fuel overboard in the event that the floats stick. This is so you don't get raw gas spilling on a hot engine.
Bikin' John
'93 Honda CB750 Nighthawk
- Damian
- Years Riding: 5
- My Motorcycle: 1994/Honda/Magna
I don't know anything about your specific bike, but it sounds like those are drain tubes. They usually drape over the battery. They are there in case you ever go down, the gas in the carbs will drain further aft, away from the sparks. They won't need to connect to anything at the opposite end.
1994 Suzuki Katana 600
1994 Honda Magna 750
- Veteran
