HELP !
HELP !
I'm hoping someone could point me in the right direction. My 2002 Honda Sabre VT1100C2 is driving me nuts rights now. On a trip to the Southeast from New Jersey, I noticed that my turn signal fuse blew. So I put a new one in and as soon I hit either the rear brake or the front brake the fuse blew again. Since I came home I've been trying to find where the problem is. I checked all the wire from mu rear turn signal/running lights conversion kit, I checked all the wires coming from my add=onl LED brake lights, I ran a test on the clutch and brake switches at the levers. But still cannot find the problem
Looks a if you have a direct short, and it is very likely at the light kit that was installed. You might try redoing the wiring to the light. Hope this helps.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
one seater
horn relocation
