HELP !
Posted: Fri Jul 20, 2007 12:06 pm
by Hodgie54
I'm hoping someone could point me in the right direction. My 2002 Honda Sabre VT1100C2 is driving me nuts rights now. On a trip to the Southeast from New Jersey, I noticed that my turn signal fuse blew. So I put a new one in and as soon I hit either the rear brake or the front brake the fuse blew again. Since I came home I've been trying to find where the problem is. I checked all the wire from mu rear turn signal/running lights conversion kit, I checked all the wires coming from my add=onl LED brake lights, I ran a test on the clutch and brake switches at the levers. But still cannot find the problem :x
Posted: Fri Jul 20, 2007 2:05 pm
by niterider
Looks a if you have a direct short, and it is very likely at the light kit that was installed. You might try redoing the wiring to the light. Hope this helps.
