As you can tell from the clip its a werid idle. I wasn't touching the throttle that was all the bike reving itself. One of cylinders is fine, the left side is the one with the erratic idle. I doubt its a back pressure issue seeing as both pipes are cut evenly but I wanted to make sure.
Do you guys think Im running the risk of a bent valve with poor back pressure?
Thanks!
http://media.putfile.com/CB500T-Exha...time-start-up-
