No voltage from pickup coil!?! 99 ZX6-R
Posted: Sat Aug 04, 2007 4:50 pm
by mahoney
The resistance is within spec on the pickup coil and the air gap between it and the rotor is within spec. I'm supposed to have 3.8volts for 5 seconds when cranking motor from p-up coil, I have none. :frusty:
Could the rotor on the crank be bad?
Everything else on the bike tests out within spec.(Switches,fuses,coils,plug wires,etc.)
Posted: Sat Aug 04, 2007 5:16 pm
by BuzZz
I doubt the rotor is bad, no experience with your particular bike, but rotors generally just spin and trigger the pick-up, if it is there, it should be working.
So that would point to the pick-up itself if everything else checks out. You may want to double check any ground straps/wires just to be sure....
Posted: Mon Aug 06, 2007 7:45 am
by mahoney
The pickup coil assembly is new from Kawi. I replaced it because I got no voltage from the old one. They both read within spec on resistance.
