Using an electric pump to change oil.
buddhacide
#1 Unread post by buddhacide »
I am setting about changing my own oil for the first time. I have the service manual and had a go last night, but I could not budge the drainbolt with all my might. Rather than mess with it, because I know i'll end up stripping it, I am entertaining the idea of an oil changer, such as one here at Canadian Tire. Is there any reason I should not use one of these?
http://tinyurl.com/2ycetc
Current: 2008 Vulcan 900 custom
Previous: 1999 V-star 650 custom
Shorts
#2 Unread post by Shorts »
Did you turn the bolt the right way? Sometimes when you're upside down, the 'right' way is actually the other way.
Squirt a little penetrating lube on the bolt head, then try it again. I'm not much for fangled gadgets :laughing: Besides, if your plug had a magnet on it, you want to remove it so you can clean off any particles that may be stuck to it.
buddhacide
#3 Unread post by buddhacide »
Yeah? Thats a good thought. Thanks.
I tried it both ways and cant budge it. I know me. Something will likely go terribly wrong, but if there is a good reason not to use one I'll figure out how to do it the old fashioned way.
scan
#4 Unread post by scan »
Righty tighty, lefty loosey.
Once you get it off, install one of these -
It's called a Sure Drain.
from these blokes -
http://www.jegs.com/
You can read my post on the topic here -
viewtopic.php?t=22884&highlight=oil+plug
* 2003 Kawasaki ZRX1200R *
