Help w/ a 83 Honda vfr750 'ceptor
ledzep12184
#1 Unread post by ledzep12184 »
Alright, I finally fixed the electrical to where all the gauges work and I can actually see whats going on with the engine. While doing this I discovered another problem... the dreaded oil leak :cry: whats the best way to attack this? It seems to be all on the back... around the valve cover and such. Is it ok to check the oil level on a kickstand - or should the bike be level. It seemed fine when I bought it two weeks ago and the only thing I did was change the plugs.
The Doctor
#2 Unread post by The Doctor »
Oil level should be check with the bike level. Concerning the leak you might have to change some gaskets, where is the oil leaking from?
insaneman_12
Years Riding: 25
My Motorcycle: Motorcycle
#3 Unread post by insaneman_12 »
Dude the valve cover gaskets on that bike should be rubber. If some idot put on the liquid gasket on it then it will be leaking. It is a common problem that I have found.
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
02 KX 85 with 75 XR 75 motor XR 200 sus.
