Also get a bit of vibration after 50+ mph...
Thanks for any input.
Your dealer may have adjusted the carbs to run a little leaner, which will cause it to run hotter. You might want to have them check it again. Don't change the oil grading, stick with what is recommended in the manual or you're liable to void the warranty if something happens to the engine as a result.MartyI wrote:Have a 2006 V-Start Classic. Had it serviced after 600 miles... now seams to run hotter than when first got it. Wondering if the oil put in it when serviced was lighter.....would putting 20w40 in help lower the heat a bit?
Also get a bit of vibration after 50+ mph...![]()
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
