backfire fireball out exhaust
2 Wheel Virgin
#1 Unread post by 2 Wheel Virgin »
Ok, I just rebuilt the carbs on my '78 CB400T and one side seems as though it runs well and the other side doesn't seem to fire at idle and at 25% throttle and up the side that didn't seem to fire, starts popping and I get an occasional fireball out the pipe. I checked the coil and the rectifier both of which are working fine and I put in new plugs in before the test and then swithced them to make sure it wasn't a bad plug. Any ideas? :frusty: Thanks.
1978 Honda CB400T
Outta the basket, and into the shop.
2004 Arctic Cat DVX400
poppygene
#2 Unread post by poppygene »
Maybe a valve issue? I think I'd do a compression test now. That might help steer you toward a solution.
#3 Unread post by BuzZz »
It sounds like a bad exhaust valve to me as well. Do as Poopy suggested and do a compression test, I bet you'll find the backfire side is pretty low.
It's a good place to start, anyways.
