A true 30 footer in the paint department. Runny thick black paint everywhere. The spare tank for the project was from a different year and needed mods to the filler area for the cap to fit. And there was actually grass in the paint on it!
Here's a shot of some parts after the clearcoat was wet sanded and buffed with the first compound.
Here's a tank closeup..bottom half not buffed, but still pretty good after wetsand with 1500 grit.
You can see the front wheel of his truck and me backlit by the sunlight. The reflections on the right are his vulcan 500, and you can see the grass, too. The other peices will be the same level of gloss, and already look good after the initial buffing.
