Getting a motorcycle in the back of a pickup!
The Doctor
#1 Unread post by The Doctor »
I just got a truck with the thought of being able to get my bike on the back. I've never done this and I have a ramp coming in the mail as well as straps.
Any tips? My main concern is getting the bike up the ramp, Should I stand beside it and have someone on the truck to guide it or should I put it up with me on it?
Thanks
slimcolo
#2 Unread post by slimcolo »
Need to know type of bike and truck. Usually best to have one or two helpers. Keep a close eye on ground clearance, Many bikes will bottom out on top of ramp. Especially true of 4WD trucks. (worse when un-loading)Best to park truck in ditch or near hill to load. Un-loading is always much harder than loading! Never trust a set of tie down straps, always have two sets on in case one breaks!
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
The Doctor
#3 Unread post by The Doctor »
Thank you for the input, is a z1000 on a 2000 Nissan frontier
erbgottie
Real Name: James
#4 Unread post by erbgottie »
I have a Ford Ranger, '04 type and fit a '07 shadow 750 on it with the gate down, had old school straps on it, just have someone compress the front shocks down as far as they can go and hooked the straps on, drove 350 miles like that and no problem at all. We use a hill like you said to load/unload and have someone guide it the bike, worked for me should do the same for you. Good luck :)
2006 Suzuki SV650S
2003 Honda RC51
scan
#5 Unread post by scan »
And always video tape. You could win some money on one of those video shows if all else goes wrong.
jk - Be careful.
* 2003 Kawasaki ZRX1200R *
NWTrtle
My Motorcycle: dream
#6 Unread post by NWTrtle »
I talked with a guy who delivers bikes from a dealership and his advice was to only compress the front shocks half way. He said this would allow the front to absorb some of the bounce from riding in the truck without causing damage to the bike. He uses straps on both sides using the handlebars and then a third across the back of the truck wound once through the rear tire.
2005 Kawasaki Ninja 500R (Sold)
2008 Hyosung GV250 (now my wife's bike)
1992 Honda Nighthawk CB250 (Sold)
--Tim
ofblong
Real Name: Ben
#7 Unread post by ofblong »
NWTrtle wrote:I talked with a guy who delivers bikes from a dealership and his advice was to only compress the front shocks half way. He said this would allow the front to absorb some of the bounce from riding in the truck without causing damage to the bike. He uses straps on both sides using the handlebars and then a third across the back of the truck wound once through the rear tire.
yeah you dont want to compress it all the way.
I would say drive it up and dont let off the gas till you are in the bed all the way :D. Or you can buy one of those tailgate lifts that you can install on your truck.
96' Honda Shadow Deluxe VLX
erbgottie
Real Name: James
#8 Unread post by erbgottie »
why would you compress them half way??? how is it going to damage your bike by compressing it down further than 1/2 way???
2006 Suzuki SV650S
2003 Honda RC51
ofblong
Real Name: Ben
#9 Unread post by ofblong »
erbgottie wrote:why would you compress them half way??? how is it going to damage your bike by compressing it down further than 1/2 way???
because then your bike has no play which can cause damage of "overtravel" not sure of the right word to use in the situation. If you leave no room for "bounce" you risk breaking all the compenents that make up the "forks".
Brackstone
Real Name: David
Years Riding: 3
#10 Unread post by Brackstone »
When I got my bike delivered the guy didn't make any adjustments. They just strapped it to the back of a flatbed and delivered it.
Aprilia Shiver 750 (sold)
