Breather tubes
wickedrider
Breather tubes
#1 Unread post by wickedrider »
What's the purpose of breather tubes?
slimcolo
#2 Unread post by slimcolo »
They vent the cam cover under the generator. This directs any blow-by on to the ground instead of blowing oil on the engine. Cars had the same thing before our Government required PCV valves. It is also known as direct crankcase ventilation.DCV
Tube, Breather oem 24912-52tb (for an XL)
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
wickedrider
#3 Unread post by wickedrider »
Thanks, slimcolo
#4 Unread post by Sev »
Uhhh, it vents some other places, basically it's to relieve pressure anywhere that it could potentially vent - crankcase, final drives, there's a couple of different places.
wickedrider
#5 Unread post by wickedrider »
Thanks Sev. OK, so here is the real issue. I removed the gas tank from my 750 Spirit yesterday. I saw the place where the tube attaches to the gas tank. However, there was no tube. Just wondering what that meant and whether it was mandatory for me to get one before I replace the tank.
slimcolo
#6 Unread post by slimcolo »
Didn't understand what you meant by breather tube before. Your last post to Sev cleared up what exactly you meant. (I think a pic next time)
Thats probably a vent/overflow tube and will leak gas directly out especially w/ a full tank. Best to replace tube, a lot cheaper than fixing bike after it catches afire.
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
wickedrider
#7 Unread post by wickedrider »
What kind of overflow? The connection is on the bottom of the fuel tank. Could the blow by be getting blown into the air filter area?
mydlyfkryzis
Years Riding: 42
#8 Unread post by mydlyfkryzis »
The crankcase vent and the fuel tank vent are different things.
Sev described the crankcase vent or breather.
The fuel tank vent/breather is different. It vents the tank. the connection may be on the bottom, but internally, it probably has a tube to the top of the tank. This vent should have a line to the ground. If your fuel tank is overfilled, or heat causes the gas to expand, the overflow comes out of this breather. You want a tube on it so gas doesn't hit a hot engine.
Richard - Fully Dressed
Naked 1976 Honda CB360T
flynrider
#9 Unread post by flynrider »
The tank vent actually serves two purposes. It allows the overflow to escape (relatively safely) in the event that the tank is overfilled, or the fuel expands. In the other direction, it allows air to enter the tank to replace fuel that has gone to the engine.
The second function is critically important. A gravity feed fuel system won't deliver fuel unless you replace the burned fuel in the tank with air. The bike will eventually stall. An even worse case is with fuel pumps. The pump will continue to pump out the fuel and the (much stronger) vacuum can cause the tank to implode.
Bikin' John
'93 Honda CB750 Nighthawk
