front wheel making noise
johnbr117
#1 Unread post by johnbr117 »
1992 nighthawk 750 47k miles I ride the highway alot In all weather except ice. Some times I hear a noise coming from the front wheel it may just be the sound of the wheel cutting through the wind but I am just concerned bearings are new (according to seller of bike) no woble everything up front is tight. I can still see a bit of blue grease in the seam between wheel and bearings so could it just be the sound of the rim cutting through the air?
new jack
niterider
#2 Unread post by niterider »
Could it be your braking system??
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
coffee_brake
#3 Unread post by coffee_brake »
Yeah, warped rotor will make a noise. So will brake pads that aren't going back into the caliper like they should.
I never saw a 90's NH yet that hadn't warped up the stock rotor. I put a floating rotor on my '92 NH 750 so that it wouldn't warp again and get noisy. It was also cheaper than another Honda rotor. Simple bolt-on fix, just don't forget to use some Locktite!
As for the caliper, I've never worked on one.
Good luck!
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
