kicked up Tail Pipe/Saddle bag cohabitation.
CapnAJ
#1 Unread post by CapnAJ »
Sorry I'm long winded. Its complicated and I cover all basis.
Here's a brief background. If you don't care skip to paragraph two. :wink: I'm riddin an 85 Yamaha Maxim 700. Nice little bike. It was sort of an opportunistic purchase. The type that was a great deal even though its not exactly what I had pictured as my next bike. I'm the type of fella with a lifestyle that demands a set of saddle bags for his bike, however if you check out a maxim you'll notice that the exhaust kicks up a bit. So that any saddle bags would be directly in the line of the exhaust.
I have a creative solution in mind but I was hoping to get some feed back and possible differing opinions.
One solution.
I could replace of adjust the pipes. New pipes would have to be custom made or matched with lots of luck. I dont have the cash to do that. Is it possible to cut the pipe where it bends and straighten it out?
Creative option I have in mind a simple(ish) fix that may or may not look... odd. BUT I might just look really cool. I could make a saddlebag support/heat shield basket. Stay with me here. Two pieces of simple bar stock will come down from either side of the rear fender. They will attach to the back side of two bolts that are already there. The two bars will attach to something of a basket which will act as a heat shield. The basket will made of aluminum with nearly a centimeter of air between two sheets, to provide insulation. Though I say basket it will only just come around the bottom edges of the bags.
Like I said this option will work structurally and indeed prevent my bags from burning/ melting, but ... well what are some thoughts here?[/u]
Big B
#2 Unread post by Big B »
one issue i could see with that is where is the heat going to go that would normally radiate off of the pipe? by installing a heat shield, you would redirect the heat back into the bike, or keep it in the pipe longer, which may cause the pipe to blue. alternatively, you also may be redirecting the heat to your shocks, chain (if it has one), and bearings, causing more wear due to that heat. i don't know if all that WILL happen, however it may be something to think about.
Fun for the whole Family!
