Easy Question, but I can't seem to find the Answer.
streetfigherzfan
#1 Unread post by streetfigherzfan »
Hello Everyone,
I've posted some others topics, for help. So my question now is: My used 99 Honda Shadow Vt600, needs a speedo cable. I bought a universal speedo cable, but I apparently need another cable to cover it. Is there a specific cable "housing" i should use?
Thanks
Dan
Big B
#2 Unread post by Big B »
why do you need another cable to cover it?
Fun for the whole Family!
MrShake
#3 Unread post by MrShake »
It looks to me like you bought one of these:
http://cgi.ebay.com/ebaymotors/Universa ... enameZWDVW
which is the inner cable by its self. If you have the old cable, you can pull the inner cable out of it and put the new one in.... or buy a new one... I've gotten cables from http://www.z1enterprises.com or from http://www.motionpro.com/search/motorcy ... nt_cables/
Both should have cables for your specific bike!
1976 Golding GL1000 Bagger
MrShake
#4 Unread post by MrShake »
There is your speedo cable from motion pro.. only like 20 bucks
http://www.motionpro.com/motorcycle/cab ... o/02-0112/
streetfigherzfan
More Specific
#5 Unread post by streetfigherzfan »
I forgot to mention: the bike that I bought, has 6 in" longer forks, so the original cable wouldnt reach. So I bought the universal inner cable, but I need the outer cable that would screw in to the speedometer itself and it screws in to a part by the front tire.
I went to a Honda dealership and they told me that i would have to find a place that would make a custom cable.
Thanks
Dan
MrShake
#6 Unread post by MrShake »
What length cable do you need?
streetfigherzfan
#7 Unread post by streetfigherzfan »
I'm not sure, i just know it needs to be 6" longer than the original.
MrShake
#8 Unread post by MrShake »
streetfigherzfan
Well its pretty ghetto!
#9 Unread post by streetfigherzfan »
Thanks for the advice, I actually bought a factory cable from Honda, which is to short, and I had previously bought a universal speedo cable (insider) and kind of spliced the outer cable and used another cable to cover the open spot ----- of the cable.
It works but I am not going to keep it like it is, unless maybe i used zipties, to keep the outer parts of the cable together....
Overall---kinda junky looking and I don't really like it!
So I am going to check out motionpro, but any other suggestions...post them please!
Thnks
Dan
