i have just bought a secondhand set of marvic penta magnesium wheels from a reputable secondhand dealer.
i saw a couple of digital shots of the rim pre purchase and was re-assured by this dealer that the rims were faultless.
when i recieved the rims i immediately noticed a large resin/glue patch on the inside of the rear rim (!)
the glue patch is hidden when the tyre is fitted (so you know where "inside " is). I called the dealer and asked why this patch was on the inside of the rim?
he said it was nothing to worry about and he knew these wheels from 2 other ducati 996's and they are perfect. but he could not explain what the patch of glue was from.
there is a large thin patch of glue about 12 square inches and quite thin. the other patch which is quite close to it, is a bit thicker, about 1/16. but only 3 square inches.
am i missing something here.
i have sent marvic an email to ask them about this......
is this a balancing trick used sometimes. or should i be putting these suspicious looking puppies aside. i peeled some of the glue off and the magnesium looked ok. the rest of the wheel looked ok corrosion wise.
help!!!!
