Suggestions for online cheap replacement air filters
flw
#1 Unread post by flw »
Where do you find the cheapest replacement filters online?
I can find it at JC Whitney but was wondering if you all have cheaper alternative sources. Mine came with paper so I either use another paper one or upgrade to foam/oil type.
Goldwing 1500se '98
VN500 LTD '07 Sold
jonnythan
Re: Suggestions for online cheap replacement air filters
#2 Unread post by jonnythan »
flw wrote:Where do you find the cheapest replacement filters online?
eBay.
slimcolo
#3 Unread post by slimcolo »
I would suggest a foam filter. They can be cleaned, re-oiled, and reused. A little more expensive at first (2-3 times the cost average) but will save money in the long run. K&N, Accell, UNI, CCI and others make these type of elements. UNI also makes bulk foam. (this can be used to make a reuseable filter If one for your bike is not made.) Most of these elements will replace stock type without any adjustments, however if you need to make your own it may need some carb adjustment. AND use a "foam filter oil" (I like K&N 'red' oil) not WD-40. (it is a lot stickier than WD-40 and removes more crap in the air)
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
