xr 250 2005 model starts then splutters and dies
assmunch13
#1 Unread post by assmunch13 »
my xr 250l 2005 model when i start it the bike splutters then dies it has a bad noise from the right side of the topend iam putting in a new cam chain did the valves that did not get rid of the noise also putting in new cam shaft bearings as they are loose can anyone give me am idea of what the problem is the carb seems fine all the tubes dont leak ive put a new spark plug in to
honda750
#2 Unread post by honda750 »
oil level's right?
economic stimulus package
insaneman_12
Years Riding: 25
My Motorcycle: Motorcycle
#3 Unread post by insaneman_12 »
First what kind of noise. Plus did you replace the cam chain tenisor when you replaced the chain. That will make a noise in the top end. Other than that piston slap will cause some noise, but you will hear it more at higher rps most of the time. I have seen a lot of problems latly where the tank does not breathe properly so it will start spudder then die a few times. Usually it is the gas cap.
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
02 KX 85 with 75 XR 75 motor XR 200 sus.
