Suzuki says to keep it under 6K RPM until 1000 miles, then to do your first oil change, then to do under so and so RPM for another 1K miles.
The reasoning behind that is because Suzukis have a bypass valve in their oil filter that opens up at a certain pressure. The oil pump is engine RPM dependent, so your RPM affects oil pressure.
The thing is, the bypass valve opens up to allow more oil through your engine at approximately 6200 RPM, meaning if you exceed that RPM you've got all kinds of floating metal pieces in your oil not going through your filter and going straight through to your engine.
That's why they suggest the lower RPMs for so many miles.
And yes, I can trust the instructor, he worked for American Suzuki directly for 15 years as a technical service adviser, regional service adviser, and factory Master Technician. Laughing
He does the first oil change at 100 miles and then rides it like he stole it, personally I'd do one at 100 miles and one at 200 miles but that's just me.
Also, switching to synthetic immediately can glaze cylinders pretty easily, so use dino oil for a couple hundred miles then switch to synthetic if you want to!
