vfr not starting
azz_vfr
vfr not starting
#1 Unread post by azz_vfr »
hi,
ive just bought a vfr 400 NC24 but it just will not start off the button, it turns over fine but will not fire, the only way i can start it is by bump starting it. any ideas. thanks, azz
#2 Unread post by Johnj »
Have you checked the side stand safety switch?
#3 Unread post by Wrider »
I'd replace your battery... It sounds to me like you don't have enough spark without the engine actually already turning under it's own power.
Skier
#4 Unread post by Skier »
Wrider wrote:I'd replace your battery... It sounds to me like you don't have enough spark without the engine actually already turning under it's own power.
A winner we have.
