Bleeding Hydraulic Valves
- coffee_brake
- Legendary 300
The '92 Nighthawk that I am re-assembling has hydraulic valves and the Clymers says I must bleed them before reinstalling them. Says there's a special tool that will force kerosene into the tappet.
Why? Do I need the special tool? Is there a way around it? Is there a generic tool or a homemade setup?
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
- Real Name: Ryan
The kerosene is to completely clean them out and flush the old oil out of them.
Not sure why you'd need a special tool on it though. If they're like the others I've seen you can just submerge them in a bath of kerosene and pump them until they're clean, then to the same in oil and reinstall them.
- coffee_brake
- Legendary 300
- Johnj
- Real Name: Johnny Strabler
I've used a set of channel-lock pliers.
![Image](http://i64.tinypic.com/wsu2on.jpg)
- coffee_brake
- Legendary 300
- coffee_brake
- Legendary 300
